Finally generated the file! Here it is. 🙂
Well, i don't understand what's going on and why are you not able to understand and follow the guide? Still, the config.plist is not upto the mark as per the guide.
  • Sad
Reactions: Chucksmmadu
Sorry i didn't realize i must use the config.plist the way it is i will upload it when i certify that there are no modifications to it 😔
Sure!
  • Love
I followed the guide, reinstalled clover from scratch. I couldn't boot with the fresh install so i attached a photo and my EFI folder i booted with usb and compressed it using the hackintosh. :) it's worth mentioning that the config.plist for native kabylake support don't have the "-v" boot arg and i added it. [It's the only modification i made to the config.plist file.] 20191124_204437.jpg
Well, it's normal.
Your files are big. Looks like you didn't followed the guide.
You must omit the unnecessary folders as mentioned.
I have recreated the problem reporting file as per the guide! 😔 20191124_204437.jpg IMG_20191125_162053.jpg IMG_20191125_164556.jpg
Thanks for helping me get this far... Sorry i'm very slow at replying... 'Pains of living in a place with poor electricity 😑' After using USB to boot and enable the change EC0 to EC, I got stuck at the aople logo that appears after the verbos logs... Which is caused by my wifi card dw1820a i guess since i haven't patched it yet... Since i don't have my screw driver to remove the wifi card, what do I do now?
No error screenshots attached. Attach the error screenshots in a .zip file.
Sorry i didn't attch any screenshot previously because i only made the change you told me to make and i successfully passed the verbos stage and I'm currently stuck at the apple logo... Ok i will attach my problem reporting file again. using USB to boot
fierofree
