AQuantia
AQC-107
AQC-113
ASUS XG-C100C
TP-Link TX401
GIGABYTE GC-AQC113C
Myri10G Drivers and Tools​
Supported models: 10G-PCIE-8A-xx, 10G-PCIE2-8B-xx, 10G-PCIE2-8C-xx and 10G-PCIE3-8E-xx
ManufacturerModelChipsetSpeed10.6.x10.7.x10.8.x10.9.x10.10.x10.11.x10.12.x10.13.x10.14.x10.15.x11.x12.x13.x
Myricom10G-PCIE-8A-xx10Gb/s
10G-PCIE2-8B-xx10Gb/s
10G-PCIE2-8C-xx10Gb/s
10G-PCIE3-8E-xx10Gb/s
Speed/Manufacturer/Type
Intel:
ModelChipsetSpeedPort TypeInterfaceDriver11.x12.x13.x14.x15.x
I210BASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I211BASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I217-V/LMBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I218-V/LMBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I219-V/LMBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I221-VBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I225-V/LM/K/I/K2/LMVP/2.5GbEBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I226-V/LM/LMVP/K/IT2.5GbEBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I340BASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I350BASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
I3541.0GbE/2.5GbEBASE-Tcom.apple.DriverKit-AppleEthernetE1000YESYES
YESYES
YESYES
X5208259910GbEBASE-T/SFP+PCIe 2.0, X8com.apple.DriverKit-AppleEthernetIXGBEYESYES
X540X54010GbEBASE-T/SFP+PCIe 2.1, X8com.apple.DriverKit-AppleEthernetIXGBEYESYES
X550X55010GbEBASE-T/SFP+PCIe 3.0, X4com.apple.DriverKit-AppleEthernetIXGBEYESYES
X7221GbE/10GbEBASE-T/SFP+PCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
V7105GbEBASE-TPCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
X71010GbEBASE-T/SFP+PCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
X710/X557-AT10GbEBASE-TPCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
XXV71025GbESFP28PCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
XL71040GbEQSFP+PCIe 3.0, X8com.apple.DriverKit-AppleEthernetIXLYESYES
E810-XXVDA2/DA425GbESFP28PCIe 4.0, X8No driver yet
E810-CQDA1/2100GbEQSFP28PCIe 4.0, X16No driver yet
XV. 700 Series
  • Supported Since: 13.2
  • Max Support: 15.x
  • Connection: Fiber, Base-T
  • Optics: SR, SRX, LR
  • DAC: Supported
  • AOC: Supported
SeriesModelControllerPortsConnectionCablingSpeedInterfaceStatusDriver11.x12.x13.x14.x15.x
700 SeriesX722-DA2X722DualSFP+DAC
SMF
MMF
1GbE/10GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesV710BASE-T5GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesX710-DA2/DA4X710Dual/Quad10GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesX710-T2l/T4L/T4X710-AT210GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesX710/X557-AT10GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesXXV710-DA2DualSFP2825GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
700 SeriesXL710-QDA1/QDA2XL710Single/DualQSFP+40GbEPCIe 3.0, X8Activecom.apple.DriverKit-AppleEthernetIXLYESYES
800 SeriesE810-XXVDA2/DA4Dual/QuadSFP2825GbEPCIe 4.0, X8ActiveNo driver yet
800 SeriesE830-XXVDA225/10/1GbEPCIe 4.0, X8ActiveNo driver yet
800 SeriesE810-CQDA1/2Single/DualQSFP28100GbEPCIe 4.0, X16ActiveNo driver yet
Mellanox:
ModelChipsetSpeedTypeDriver
CX4121A-ACAT ConnectX-425GbESFP28com.apple.DriverKit-AppleEthernetMLX5
XV. T5 Series
  • Max Support: 15.x
  • DAC: Supported
  • AOC: Supported
ModelControllerPortsTypeSpeedInterfaceDriver11.x12.x13.x14.x15.x
T580-CRX722DualSFP+1GbE/10GbEPCIe 3.0, X8com.cxgbYESYESYES
T580-SO-CRBASE-T5GbEPCIe 3.0, X8com.cxgb YESYES
T580-LP-CRX710Dual/Quad10GbEPCIe 3.0, X8com.cxgb YESYES
T580-CRX710-AT210GbEPCIe 3.0, X8com.cxgb YESYES
T540-LP-CR 10GbEPCIe 3.0, X8com.cxgb YESYES
T540-SO-CR DualSFP2825GbEPCIe 3.0, X8com.cxgb YESYES
T520-BTXL710Single/DualQSFP+40GbEPCIe 3.0, X8com.cxgb YESYES
T520-CRDual/QuadSFP2825GbEPCIe 4.0, X8com.cxgb
T520-SO-CRSingle/DualQSFP28100GbEPCIe 4.0, X16com.cxgb
T520-LL-CR
Solarfare
Broadcom
  • BCM5722
  • BCM5754
  • BCM5754M
  • BCM5755
  • BCM5755M
  • BCM57788
  • BCM5787
  • BCM5787M
  • BCM5906
  • BCM5906M
Hi! Are either of my drivers supported? Both Ethernet and WiFi below.
Realtek RTL8125 LAN driver V1125.9.614.2022 (Ethernet) or Realtek RTL8852BE WiFi driver V6001.15.124.0 (WiFi) for MacOS 11 Big Sur or MacOs 12 Monterey?
I felt this was the best place to ask.
Edit: I am asking about 11 and 12 because I do not know if my 1060 3GB can run anything higher than that. I already saw that they do not support the current GPU I use which is the NVIDIA RTX 3070.
Ethernet is supported but the WiFi isn't. You must replace it with a compatible adapter. 1060 can be patched on higher version but highly experimental. None of the RTX GPUs are supported as of now.
Anyway to get Atheros Killer 3100X to work? I hear it shows in Hackintool as Intel.
ASRock Z790 PG-iTX
Sonoma
ASRock Z790 PG-iTX
Sonoma
Attach Hackintool PCIe Info.
Here you go
Intel Killer E3100G the same as E3100X? Working Out of the box?
Reactions: exefes
Hi guys, I have purchased a CX4121A-ACAT ConnectX-4 card after reading this post but I can't make it working in Sonoma. The card is in a PCIe slot, and it is seen by the system, recognized as Ethernet card, but no driver is loaded. (The card works fine in Windows 11.) The AppleEthernetMLX5 can't load, it crashes EXC_BAD_ACCESS exception. Its parent class is IOSkywalkFamily, for which I am trying to load the original Apple version from System/Library/Extensions, but it is not loading, I can see this in sysinfo: "Kext has a CFBundleExecutable property but the executable can't be found: IOSkywalkFamily". So this is where I am stuck now.
I am not sure I understand the exact reason why IOSkywalkFamily had to be replaced by an external kext, I thought it was because of missing Broadcom support - but does this also mean that I need to use the OpenCore version of IOSkywalkFamily, with the same extra steps as if I was using it for a Broadcom wifi driver? I have tried loading the OC version but that did not work either.
Has anyone made this card - or any other Mellanox card that uses the AppleEthernetMLX5 driver - working under Sonoma?
copperbarg
