Reactions: mackul19
Where do I download OcBinaryData.zip? The search here is pretty lousy.
Nevermind ... googled it and found the github.
Hello there i have a problem when tryin to install macos, where it says that is not compatible for my board, i have a Mother board Tuf b450m-PLUS with a Ryzen 7 5700g using the apu, am i doing something wrong or its not posible, ive tried from high sierra to monterey with no luck, any clues?
You're probably using the wrong SMBIOS. Use MacPro1,1 and you should be able to start the installation!
Reactions: Alexandeer
Hello thanks, i guess it did help but now i only get this error :
No schema for FixupAppleEfiImages at 8 index, context <Quirks>!
LNX: AutodetectLinux not root fs - Not Found
I do recognize the first but not he second line, and cant seem to fix it, any clues? sorry, im kinda new in all this
Simply uncheck the FixupAppleEfiImages in Booter Quirks.
Are you currently using Linux?
dmitriy103
