Lenovo thinkbook 15p
This is the last configuration I tested:
For the moment, you ned to enter the BIOS and provide the settings it has.
Regarding the issue, you have ResizeAppleGpuBars Enabled. Disable it using the value -1 in the Booter>Quirks section and you should be able to boot.
How to change the bios I have no effect always gives this error.
With the newest version bios I am: F6CN30WW (Bios is factory locked by lenovo and has no advanced settings)
Can we make a mistake when configuring EFI
OhCamargo
