hp 255 g8
palladinoandrea
Can I install mac os any version on my system?
CPU : AMD 5700u
GPU : integrated card
RAM : 16gb
WIFI\BLUETOOTH: Realtek 8852AE
the PC suddenly freezes and shuts down
CPU : AMD 5700u
RAM : 16gb
Yes, you can.
Please provide the EFI you're using.
Not working:
  1. The camera is no longer seen
  2. Microphone not working (but seen in settings)
  3. Screen brightness does not work
  4. When I click on screen saver, it tells me that it is impossible to complete the operation (error 15)
  5. No hdmi audio
  6. No DRM support and iGPU performance
How can I fix these bugs?
And was it working before?
What's your Audio Codec?
Is your Graphics acceleration working?
The screen brightness does not work via Keyboard hotkeys or via the slider.
The screen saver works normally. Seems like the Graphics acceleration isn't proper or something is missing and/or conflicting.
No hdmi audio
This is a bug for now on a few platforms.
Is expected
Only on Facetime it works, if I use other apps it crashes
acl 236 and it works (headphones etc) but the microphone doesn't, on windows it is seen as an array microphone
no because if I run VDADecoderCreate failed. I have error -12473
I also noticed that the USB C 3.1 and the camera are not always connected (seen with hacktools). Let me explain better, they are green but do not give the name of the device
Might need to patch with AMDFriend.
Custom XML patching might be required in your case if you have tried all the recommended layout IDs.
Provide a Desktop picture.
That's normal. You'll need to use SSDT to fix those little errors.
I haven't the slightest idea how to do it... I read that there is a kext called AMDMicrofone as well as version 1,8,8 which should have solved these bugs.
This is image:
Screenshot 2024-02-06 alle 07.51.44.png Screenshot 2024-02-06 alle 07.50.12.png Screenshot 2024-02-06 alle 07.50.43.png
Never tried it. xD
According to the pictures, Graphics seems to be working.
izzykaif
