SOLVED is it possible hackintosh in amd ryzen 5 5600h
Hello, I wanted to ask, I can't understand I download archives from the git hub, but there are no kexts in them. Copy the required kexts with .kext extension to EFI/OC/Kexts directory. Help me please
You need to download the kext release, unzip and then you can get the kexts.
To download a zip archive from GitHub, you need to either log in on your computer or select the PC version on your smartphone in the browser, then you will see a green button at the top right, and you can select download the zip there.
I was able to boot into Macos, I formatted the partition in appfs and gave it a name, then when the installation is in progress, the download is completely filled and at the bottom it gives an inscription with the time how long to wait and it is equal to 2 hours 58 minutes and then nothing happens, please help anyone who can help. I don’t know how to post a photo so I would post it.
I found a button to insert a photo
Is this via online installer or offline?
Are you installing on External Drive?
What's the drive model?
thank you all, I already installed it and it works
fly.gao
