Is it possible to enable GPU acceleration Radeon RX 580?
I am asking because you said to go for Gigabyte/Sapphire/MSI
That's right!
Those are the preferred choice
RX580 4GB and 8GB variants are supported. If the XFX works, all good. If not, you'll need to cross flash a compatible VBIOS.
Alright, I will buy it in November then!
Sounds good!
In the dortania guide it says that RX 6600 is supported
Yes, its supported!
Yes, its supported!
OOTB?
Does it work OOTB or I need to patch it?
jonnyrec
