Is it possible to enable GPU acceleration Radeon RX 580?
I am asking because you said to go for Gigabyte/Sapphire/MSI
RX580 4GB and 8GB variants are supported. If the XFX works, all good. If not, you'll need to cross flash a compatible VBIOS.
Alright, I will buy it in November then!
In the dortania guide it says that RX 6600 is supported
Yes, its supported!
mohthearrow
