HDMI output issues
zeinos
legion 5 15arh05
ryzen 7 4800h
nvidia gtx 1650
I am having an issue with HDMI output after successfully hackintosh my laptop, I can't output to the screen anymore through the HDMI port. My laptop's iGPU is AMD Radeon Graphics 512MB (CPU is AMD Ryzen 7 4800H) maybe aka AMD Radeon Vega 7, dedicated graphics is disabled and in the DP section i have deleted all. Is there any way for me to output to HDMI?
This is config file:https://github.com/ZeinosNSB/EFI/blob/main/OC/config.plist
My specs:
Legion 5 15ARH05
CPU: Ryzen 7 4800H with Radeon Graphics
GPU: GTX 1650 (disabled)
Ssd: WD SN850X 1TB(for MacOS)+ Samsung 512GB(for Win)
Ethernet:Realtek 8168/8111
Wifi+Bluetooth: Intel Ax200
Audio codec: Realtek ALC257
My specs:
Legion 5 15ARH05
Firstly you should check whether the HDMI Port is tied to APU or dGPU. If its tied to dGPU, unfortunately, you cannot drive a display via that at least on macOS.
radek60
