Z590i Instant dark wake due to RP21 (PCI bridge?)
buzuddha
Z590i Vision D
i7-11700K
AMD RX580
12.x
Hi All,
Nearly complete hack here. Just need to fix sleep. EFI is a fork of SchmockLord's - all credit due for USB port map and general set up. Re-dumped DSDT and generated my own EC/PLUG/HPET/USBX/RTCAWAC just in case and applied relevant patches.
Initially had instant wake:
Wake from Normal Sleep [CDNVA] : due to XDCI CNVW USBW RP21/UserActivity Assertion Using AC (Charge:0%)
Ran the prep for fixing sleep from Dortania.
sudo pmset autopoweroff 0
sudo pmset powernap 0
sudo pmset standby 0
sudo pmset proximitywake 0
sudo pmset tcpkeepalive 0
I applied the GPWR.aml and patch. This all fixed 3 items waking things up, but still have dark wake (screen off but fans on).
DarkWake from Normal Sleep [CDN] : due to RP21/ Using AC (Charge:0%) 30 secs
Added the bootarg "darkwake=0" but that just gives full wake with screen and all:
Wake from Normal Sleep [CDNVA] : due to RP21/UserActivity Assertion Using AC (Charge:0%)
So not that.
RP21 is some kind of PCI bridge for the motherboard 500 chip I guess
IOService:/AppleACPIPlatformExpert/PC00@0/AppleACPIPCI/RP21@1B,4
PciRoot(0x0)/Pci(0x1B,0x4)
8086:43C4
PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11)
    Kernel driver in use: pcieport
OS: 12.7.2 (21G1974)
SMBIOS: MacPro7,1
MoBo: Z590i Vision D
CPU: 11700K
GPU: RX580
WiFi/BT: BCM943602CDP (native)
Dunno how to fix this. Would be very grateful for any help here. Attached EFI.zip and screenshots of RP21. Also yes I am aware there are some Sonoma specific fixes for networking stuff in my EFI, but don't use these and they don't seem to hurt anything in Monterey.
Thanks!!
  • EFI.zip
    EFI.zip
Ok according to chatGPT, I would add the following to device properties:
<key>DeviceProperties</key>
<dict>
    <key>Add</key>
    <dict>
        <key>PciRoot(0x0)/Pci(0x1B,0x4)</key>
        <dict>
            <key>wake</key>
            <data>
                <!-- Set to Data value indicating false -->
            </data>
        </dict>
    </dict>
</dict>
Anyone know where I could find what value to use to set wake to false here?
Hi All,
So not that.
8086:43C4
SMBIOS: MacPro7,1
CPU: 11700K
GPU: RX580
Thanks!!
Your EFI is not as per the guide. Attach BIOS Settings+IOReg.
fly.gao
