SOLVED Kernel Panic on Ventura | 7600X and 6700XT
metamorphosis
MSI Pro B650M-P
Ryzen 5 7600x
RX 6700XT
  1. Mac Pro
I am getting [EB|LOG:EXITBS:START] error on my rig. Although I followed all the instructions properly and even manually setup my kexts. Saw the new video saying 6700XT has a workaround now, so wanted to try it out . And also used NootRX instead of Whatevergreen. All the recommended bios settings was applied as well. Still facing this error!
Thank you for any kind of help
config.plist - https://drive.google.com/file/d/1lqU-I-S9wuHDsfNjcwG5TgDFIHKdHBWX/view?usp=sharing
Kernel panic is different and getting stuck whole booting is different.
Your configuration is not as per the guide. Moreover, 7000 series requires MMIOWhitelist.
Yes, thanks for the reply. I fixed it! MMIO whitelist wasn't required but i did it anyways after booting into macOS, the problem I was having was I didnt include VirtualSMC kext, Idk, how I missed it! My bad. Anyways, after a whole lot of hardwork and patience , I finally got it working! Everything is running well, except the bluetooth. Not like i need it anyways, so I just deleted all the kexts related to Broadcom.
Glad to hear. Closing the thread.
Reactions: metamorphosis
biff
