Kernel Panic on Ventura 13.6.1
kaoz
ASUS TUF Gaming Z690-PLUS WiFi D4
Alder Lake i7-12700KF
AMD RX 580
  1. Mac Pro
Ventura crash after 10 mins since boot and always with this kernel panic
please help me to fix that... before never happened... dunno what could be, the only difference than usual use is i was trying to fix my printer epson al-m200dn that don't print anymore on ventura
panic(cpu 18 caller 0xffffff8014992538): PTE Corruption detected: ptep 0xfffffea28278a020 pte value 0xfeb9000000000000 clear 0x1 set 0x0 @pmap.h:478
Panicked task 0xffffff9d23160e18: 5 threads: pid 157: corebrightnessd
Backtrace (CPU 18), panicked thread: 0xffffff98585b9598, Frame : Return Address
0xffffffb0832db700 : 0xffffff8014870c7d mach_kernel : _handle_debugger_trap + 0x4ad
0xffffffb0832db750 : 0xffffff80149c4f54 mach_kernel : _kdp_i386_trap + 0x114
0xffffffb0832db790 : 0xffffff80149b4a67 mach_kernel : _kernel_trap + 0x3b7
0xffffffb0832db7e0 : 0xffffff8014811971 mach_kernel : _return_from_trap + 0xc1
0xffffffb0832db800 : 0xffffff8014870f5d mach_kernel : _DebuggerTrapWithState + 0x5d
0xffffffb0832db8f0 : 0xffffff8014870607 mach_kernel : _panic_trap_to_debugger + 0x1a7
0xffffffb0832db950 : 0xffffff8014fdb9ab mach_kernel : _panic + 0x84
0xffffffb0832dba40 : 0xffffff8014992538 mach_kernel : _pmap_nest + 0xc18
0xffffffb0832dba70 : 0xffffff80149936ba mach_kernel : _pmap_enter_options + 0x4ba
0xffffffb0832dbb70 : 0xffffff8014912907 mach_kernel : _vm_fault_enter + 0x1557
0xffffffb0832dbbf0 : 0xffffff80149114e8 mach_kernel : _vm_fault_enter + 0x138
0xffffffb0832dbc70 : 0xffffff801490ff21 mach_kernel : _vm_fault$XNU_INTERNAL + 0x1ce1
0xffffffb0832dbef0 : 0xffffff80149b5258 mach_kernel : _user_trap + 0x2b8
0xffffffb0832dbfa0 : 0xffffff801481189f mach_kernel : _hndl_alltraps + 0x5f
Process name corresponding to current thread (0xffffff98585b9598): corebrightnessd
Boot args: -v keepsyms=1 debug=0x100 alcid=12
Mac OS version:
22G313
Kernel version:
Darwin Kernel Version 22.6.0: Wed Oct 4 21:25:26 PDT 2023; root:xnu-8796.141.3.701.17~4/RELEASE_X86_64
Kernel UUID: 6059599F-7994-349C-8DC6-03F3B60C83DE
roots installed: 0
KernelCache slide: 0x0000000014400000
KernelCache base: 0xffffff8014600000
Kernel slide: 0x00000000144dc000
Kernel text base: 0xffffff80146dc000
__HIB text base: 0xffffff8014500000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 634211413592
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000093a9f23065
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x0000001a4baeb6e7 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff8856f5b000 - 0xffffffa856f5b000
. PGZ : 0xffffff8856f5b000 - 0xffffff885af5c000
. VM : 0xffffff885af5c000 - 0xffffff8d2728f000
. RO : 0xffffff8d2728f000 - 0xffffff8ec08f5000
. GEN0 : 0xffffff8ec08f5000 - 0xffffff938cc28000
. GEN1 : 0xffffff938cc28000 - 0xffffff9858f5b000
. GEN2 : 0xffffff9858f5b000 - 0xffffff9d2528e000
. GEN3 : 0xffffff9d2528e000 - 0xffffffa1f15c1000
. DATA : 0xffffffa1f15c1000 - 0xffffffa856f5b000
Metadata: 0xffffffffb9aec000 - 0xffffffffd9aec000
Bitmaps : 0xffffffffd9aec000 - 0xffffffffdfaec000
Extra : 0 - 0
Panic(CPU 0): PTE corruption detected on PTEP 0xfffffea28278a020 VAL 0xfeb9000000000000
RAX: 0x0000000000000020, RBX: 0x0000000000000001, RCX: 0x0000000000000001, RDX: 0x0000000000000000
RSP: 0xffffffb08388fec0, RBP: 0xffffffb08388fef0, RSI: 0xffffff80156589c0, RDI: 0xffffff80154f84e8
R8: 0x0000000000000000, R9: 0x0000001f3e7424f2, R10: 0xffffff8015658980, R11: 0x0000000000000000
R12: 0x0000000000000020, R13: 0x0000000000f7ef92, R14: 0x00000093a9e1ffcc, R15: 0x0000000000000000
RFL: 0x0000000000000046, RIP: 0xffffff80149c9e92, CS: 0x0000000000000008, SS: 0x0000000000000010
Panicked task 0xffffff9d251879d8: 229 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff9858ec8b30, Frame : Return Address
0xffffff805eac7e40 : 0xffffff80149bea71 mach_kernel : _smp_init + 0x491
0xffffff805eac7f80 : 0xffffff80149b43b6 mach_kernel : _interrupt + 0xd6
0xffffff805eac7fe0 : 0xffffff8014811a9a mach_kernel : _hndl_allintrs + 0x9a
0xffffffb08388fef0 : 0xffffff80149b6fc2 mach_kernel : _machine_idle + 0x1c2
0xffffffb08388ff10 : 0xffffff80148a1e28 mach_kernel : _processor_idle + 0x148
0xffffffb08388ff80 : 0xffffff80148a2168 mach_kernel : _idle_thread + 0x48
0xffffffb08388ffa0 : 0xffffff801481119e mach_kernel : _call_continuation + 0x2e
Process name corresponding to current thread (0xffffff9858ec8b30): kernel_task
Panic(CPU 1): PTE corruption detected on PTEP 0xfffffea28278a020 VAL 0xfeb9000000000000
RAX: 0x0000000000000020, RBX: 0x0000000000000002, RCX: 0x0000000000000001, RDX: 0x0000000000000000
RSP: 0xffffffb083a2bec0, RBP: 0xffffffb083a2bef0, RSI: 0xffffff8015658d40, RDI: 0xffffff80154f84e8
R8: 0x0000000000000006, R9: 0x0000001a8957ab68, R10: 0xffffff8015658980, R11: 0x0000000000000000
R12: 0x0000000000000020, R13: 0x0000000000e4760a, R14: 0x00000093a9e1de9d, R15: 0x0000000000000001
Backtrace (CPU 1), panicked thread: 0xffffff9858ed50c8, Frame : Return Address
0xffffff8836f47e40 : 0xffffff80149bea71 mach_kernel : _smp_init + 0x491
0xffffff8836f47f80 : 0xffffff80149b43b6 mach_kernel : _interrupt + 0xd6
0xffffff8836f47fe0 : 0xffffff8014811a9a mach_kernel : _hndl_allintrs + 0x9a
0xffffffb083a2bef0 : 0xffffff80149b6fc2 mach_kernel : _machine_idle + 0x1c2
0xffffffb083a2bf10 : 0xffffff80148a1e28 mach_kernel : _processor_idle + 0x148
0xffffffb083a2bf80 : 0xffffff80148a2168 mach_kernel : _idle_thread + 0x48
0xffffffb083a2bfa0 : 0xffffff801481119e mach_kernel : _call_continuation + 0x2e
Process name corresponding to current thread (0xffffff9858ed50c8): kernel_task
Panic(CPU 2): PTE corruption detected on PTEP 0xfffffea28278a020 VAL 0xfeb9000000000000
RSP: 0xffffffb083a9bec0, RBP: 0xffffffb083a9bef0, RSI: 0xffffff80156590c0, RDI: 0xffffff80154f84e8
R8: 0x0000000000000005, R9: 0x00000013600f89ea, R10: 0x00000000000fffff, R11: 0x0000000000000004
R12: 0x0000000000000020, R13: 0x07fffffffde0308e, R14: 0x00000093a9e272c3, R15: 0x0000000000000002
Backtrace (CPU 2), panicked thread: 0xffffff9858ee0598, Frame : Return Address
0xffffff8836f27e40 : 0xffffff80149bea71 mach_kernel : _smp_init + 0x491
0xffffff8836f27f80 : 0xffffff80149b43b6 mach_kernel : _interrupt + 0xd6
0xffffff8836f27fe0 : 0xffffff8014811a9a mach_kernel : _hndl_allintrs + 0x9a
0xffffffb083a9bef0 : 0xffffff80149b6fc2 mach_kernel : _machine_idle + 0x1c2
0xffffffb083a9bf10 : 0xffffff80148a1e28 mach_kernel : _processor_idle + 0x148
0xffffffb083a9bf80 : 0xffffff80148a2168 mach_kernel : _idle_thread + 0x48
0xffffffb083a9bfa0 : 0xffffff801481119e mach_kernel : _call_continuation + 0x2e
Process name corresponding to current thread (0xffffff9858ee0598): kernel_task
Panic(CPU 3): PTE corruption detected on PTEP 0xfffffea28278a020 VAL 0xfeb9000000000000
RSP: 0xffffffb0835a3ec0, RBP: 0xffffffb0835a3ef0, RSI: 0xffffff8015659440, RDI: 0xffffff80154f84e8
R8: 0x0000000000000005, R9: 0x00000011dd32fee0, R10: 0x00000000000fffff, R11: 0x0000000000000008
R12: 0x0000000000000020, R13: 0x0000000000e3e1ea, R14: 0x00000093a9e272bd, R15: 0x0000000000000003
Backtrace (CPU 3), panicked thread: 0xffffff9858edf0c8, Frame : Return Address
0xffffff8836f3fe40 : 0xffffff80149bea71 mach_kernel : _smp_init + 0x491
0xffffff8836f3ff80 : 0xffffff80149b43b6 mach_kernel : _interrupt + 0xd6
0xffffff8836f3ffe0 : 0xffffff8014811a9a mach_kernel : _hndl_allintrs + 0x9a
0xffffffb0835a3ef0 : 0xffffff80149b6fc2 mach_kernel : _machine_idle + 0x1c2
0xffffffb0835a3f10 : 0xffffff80148a1e28 mach_kernel : _processor_idle + 0x148
0xffffffb0835a3f80 : 0xffffff80148a2168 mach_kernel : _idle_thread + 0x48
0xffffffb0835a3fa0 : 0xffffff801481119e mach_kernel : _call_continuation + 0x2e
Process name corresponding to current thread (0xffffff9858edf0c8): kernel_task
Panic(CPU 4): PTE corruption detected on PTEP 0xfffffea28278a020 VAL 0xfeb9000000000000
RSP: 0xffffffb083a73ec0, RBP: 0xffffffb083a73ef0, RSI: 0xffffff80156597c0, RDI: 0xffffff80154f84e8
R8: 0x0000000000000005, R9: 0x0000000e9304f306, R10: 0x00000000000ffff
Mac OS version:
22G313
Kernel version:
roots installed: 0
Zone info:
Extra : 0 - 0
If you installed any particular kext, probably that's causing the issue. Try to boot via Recovery and check if it boots.
alvarg82
