HP ZBook/Firefly 14 G10 AMD
ok so what I am looking now is windows laptop alternative for macbook air 15" so I could use there osx. size(15") built(thin) speed (M2like) and weight. which laptop would you suggest?
edit. you there mate?
processor AMD Ryzen 7 7840S and IGPU amd 660 are these supported?
Last few days have been busy here.
Your max option is any Intel or AMD Laptop (higher generation) with a dedicated GPU with an option to either switch between IGPU and dGPU or where the IGPU is factory disabled.
The safest option is to get an Ice Lake Laptop!
Unfortunately, no support for the APU on macOS yet.
hmmm that bad. I have now
Lenovo Yoga Slim 7 14APU8 Tidal Teal​
AMD Ryzen 7 7840S
AMD Radeon 780M
AMD Ryzen 7 7840S
AMD Radeon 780M
OS can be installed but no APU support.
if apu means processor how can osx can be installed if cpu is not supported?
CPU is the Processor and APU is AMD's IGPU.
I see but if graphic card is not supported is statement that os can be installed valid?
rbrb
