WIFI not working on build hackintosh
Kunio
Asus b250M-A
Intel i3-7300
AMD Radeon R7 265 2 GB
  2. OpenCore (Legacy)
  1. iMac Pro
hi! I need some help to get my Broadcom wifi card working on my hackintosh. I already try the guide but its not working,
my machine is a
Asus B250M-A
Intel i3-7300
16gb DDR4
WIFI Broadcom BCM4360 using a PCI adapter
my machine is a
Asus B250M-A
Intel i3-7300
16gb DDR4
Hello,
Please attach the EFI you're using to boot. Also, what macOS version are you on?
Hello,
I'm using OpenCore 0.9.7 and running macOS 14.1.1
EFI is missin
I’m confused, I thought opencore was the EFI, not just the configurator/editor app that applies the config.plist and opencore.efi in the efi partition
I downloaded the files from
GitHub, including some kexts, but I don’t remember what version of opencore said it was
What's confusing here? If the WiFi is not working, you need to attach the EFI you're using to boot so that we can check where the problem is coming from.
this is what I have
this is the full EFI folder from the EFI partition. im sorry if I sound dumb, I don't really know much about EFI partitions or boot loaders on PC, just some out dated knowledge about boot loaders on android phones from 10 years ago
No worries. Attach Hackintool PCIe Tab screenshot or export and attach the file.
uixhc7ha
