NootedRed Kext screen problem
Why using EnableWriteUnprotector and RebuildAppleMemoryMap together? The guide strictly says not to use them together.
If the internal screen is black, try iMac20,1 SMBIOS. Also, attach your BIOS Settings.
Hello,
I disabled RebuildAppleMemoryMap
So, I used remote control from another pc and I found Built-in display has NaN Inch (0 x 0)
About BIOS Settings I get two options for boot:
SecureBoot is disabled
Fastboot disabled too
Bios Version : 2.20.1271 American Megatrands, Inc.
Hello,
No idea without the PR Files.
Incomplete PR Files attached.
Kextcache output, IOReg, System Report, Hackintool reports are missing.
NootedRed is disabled in the config.plist. You must enable it first. There's an update to the kext we just added up. Replace with that.
Also, disable EnableWriteUnprotector and enable RebuildAppleMemoryMap.
Reset NVRAM twice and check if you have a display now.
I got kernel panic
xmax114
