NootedRed Kext screen problem
Yes, I'm using the latest kext updated
Is there any Graphics related setting in BIOS?
Also, did you enable the NootedRed.kext in config.plist?
no Graphics related setting in the bios,
NootedRed kext is enabled on the config plist
Attach the new PR Files. Also attach a video of the issue. With and without the external monitor and IOReg and System report for both.
The screen doesn't seems to be connected. Try with a clean install. If that doesn't helps, try running Ventura. Also, try to disable NootedRed.kext and check if you can get the display on your internal screen.
About nootedred kext when it disabled, the internal screen works but detected as "unknown monitor/display" it's doesn't work when I activated it.
I'll try to reinstall macos and if doesn't work I'll install macos 13 Ventura
Sounds good!
Alisson de Santana
