MacOS Mojave 10.14.5 (18F132)-GPU?
Check your EFI folder and make sure you are using the latest version of Lilu and WhatevrGreen and do not inject anything GPU related except for iGPU setting if it is enabled in BIOS/UEFI.
Thanks
I used hackintool to update lilu, whatevergreen, but unfortunately it didn't work.
RX580 can be correctly identified, I think it may be a hardware problem?
Thanks
Probably, this issue is due to Intel UHD Graphics enabled or a faulty DP/HDMI cable. Provide PR files.
Thanks
post your EFI folder so I can take a look. if the display is normal in BIOS and post and even the Clover GUI so the issue is not the GPU it must be settings or the OS itself.
Thanks,
I am sure that the Intel UHD in the BIOS is disabled and the DVI cable is good (when I used 1050Ti, display is normal).
Sorry, I don't know what is the PR files?
Thanks, the attachment is my EFI files.
My Lilu.kext and WhateverGreen.kext are installed in the L/E directory, the Lilu.kext version is 1.3.8, and the WhateverGreen.kext version is 1.3.2.
Sorry, it's my mistake.
I have fixed my report file, thanks.
Your config.plist file is not upto the mark. Grab the config.plist file from this guide: https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/
AptioMemoryFix-64.efi and OsxAptioFix2Drv-free2000.efi should not be used together. Use only one. The preferred choice is AptioMemoryFix-64.efi.
Remove all the kexts from L/E. All of them.
Follow the guide here: https://www.elitemacx86.com/threads/install-macos-mojave-on-pc.264/
Reply with new files.
I have tried to modify my config.plist and kexts, but it still fails. But just after I switched to using HDMI, everything is fine (DVI port output is problematic), however I still hope to find out where my problem is.
Now I have to try to solve the problem that my usb port 3.0 not work. Later, I will upload my modified config.plist and reporting files, thank you both for your help and patience.
No PR files attached after modifications. For DVI and other ports, you might have to patch the framebuffer and matching ports.
Yes, you must attach PR files. As per your profile, you're using 10.14.6. Follow the USB guide here: https://www.elitemacx86.com/threads/fix-usb-port-limit-10-14-4-by-©pmheart.365/
rbrb
