OC: Configuration requires vault but no vault provided.
Eddieee95
Dell Inspiron 15 3521
Intel(R) Core(TM) i3-3227U CPU @ 1.90GHz 1.90 GHz
Intel HD Graphics 4000
10.13.x
  1. Other
I have made the EFI file for my processor according to the guide i Found here
and also downloaded the latest com.apple.recovery file using the CMD.
after setting everything up, I have made sure my config.plist file have no errors
but when I try to Boot to my EFI usb its showing error like this
OC: Configuration requires vault, but no vault provided
what is the reason for this error prompt and how to solve this???
I have provided my EFI file below.
this is the EFI file for Intel core i3 3327u processor that I have made using the guide I found here.
OPENCORE version: 0.9.5 RELEASE
https://mega.nz/folder/Y5BnUJTJ#8o-G3BYA_n_1szwLWkosQQ my files
That's because you have set the Vault to Secure. Set the Vault to Optional in Misc>Security section of your config.plist.
Reactions: Eddieee95
oh thanks sir.. i will do it then
Write your reply...
ambruhidot
