Request for EFI Configuration for macOS Ventura on Ryzen 7 5700U (GenMachine Ren5000)
Fynlix
Hello everyone,
I'm trying to get macOS Ventura running on my GenMachine Ren5000 mini PC but haven’t found a fully working EFI configuration yet. I’ve tried multiple EFI setups without success, so I'm hoping someone might have a working EFI for a similar system.
System Specifications:
  • CPU: AMD Ryzen 7 5700U
  • RAM: 20GB DDR4 3200MHz
  • Graphics: AMD Radeon™ Graphics (Vega iGPU)
  • Storage: Western Digital 500GB WD Blue SN550 NVMe
  • Ethernet: Realtek RTL8111
  • Wi-Fi/Bluetooth: Fenvi BCM94360NG (macOS compatible)
If anyone has a functional EFI folder for this setup or can recommend one that has been tested, it would be greatly appreciated. Thanks in advance!
I have an EFI folder configured specifically for the GenMachine Ren5000, but it’s set up for a Ryzen 7 5800U processor. I need to adapt it to work with my Ryzen 7 5700U setup
If this is your's EFI, then you should be able to adapt the changes. If not, follow the guide from scratch!
It's not work and i don't know how to resolve this
If it does not work, you're supposed to attach the photo/video of the error and provide your EFI to check further!
chrisgamessss
