INFO EFI folder
Fonico87
ASUS P8Z77-V Deluxe
Intel i7-3770K
Nvidia GeForce GTX 1050 Ti
Hi everyone, I have a problem during installation.
More or less, the installation reaches 90%, after which I have continuous reboots with different errors each time.
I swear I spent hours and hours reading your guides, I thought I created the EFI folder correctly, but unfortunately it's not right.
Kindly, could someone check the EFI folder and possibly correct it?
My hardware is already signed.
I know, my PC is old but I can't buy another one at the moment. :D
Thank you!
Thank you!
Thank you, I've been trying and trying again for two days. I can not make it. Could you kindly pass me the EFI folder? I'm literally going crazy 🥴
Why not read the guide in the first place, prepare the files and then seek help?
Believe me I did it, step by step and I only added the files that the guide said. But it wouldn't even start. I found a ready-made folder online, and it's the one that allowed me to get to 90% of the installation, only after that I had endless reboots. The last Hackintosh I dealt with was Yosemite, it was easier then using Unibeast and Multibeast 😔
No, you didn't. If you have followed the guide, the EFI should reflect the changes. You need to start from scratch and the problems will be solved. Moreover, your hardware support is limited so you can install High Sierra (max) for the Graphics acceleration.
Yes, I know, I wanted to try Sonoma and use the Intel HD 4000 iGPU. But I can't really figure it out, I don't understand where I'm wrong or if my PC is incompatible. 🤷🏻
No doubt, your system is compatible. For the IGPU, that needs to be patched under macOS Sonoma. However, the reason why the installation is having issues is because of the mess in the EFI. Until you start from scratch, put efforts, you'll be in loop.
sdfsad
