EFI for latitude 7300
Khang
Latitude 7300
I5-8265U
Uhd 620
15.x
Can some one help me build EFI for my latitude 7300
  • Intel Whiskey Lake i5-8365U CPU
  • Intel UHD620 graphics
  • 16GB RAM
I was try to make one with ocauxiliarytools but this problem always show up and then reboot my laptop
  • 16GB RAM
If the Laptop reboots, there is a possibly Kernel Panic. Remove HackrNVMeFamily kext and then check. Also, it could be possible that your Laptop has less than 32MB DVMT which can cause KP. Ensure that your kexts are up to date.
Can you help me make an EFI for my laptop
NCC74656
