 - Nov 18, 2024
 - Latitude 7300
 - I5-8265U
 - Uhd 620
 - 15.x
If the Laptop reboots, there is a possibly Kernel Panic. Remove HackrNVMeFamily kext and then check. Also, it could be possible that your Laptop has less than 32MB DVMT which can cause KP. Ensure that your kexts are up to date.Can some one help me build EFI for my latitude 7300
I was try to make one with ocauxiliarytools but this problem always show up and then reboot my laptop
- Intel Whiskey Lake i5-8365U CPU
 - Intel UHD620 graphics
 - 16GB RAM
EFI.zip
drive.google.com
Can you help me make an EFI for my laptopIf the Laptop reboots, there is a possibly Kernel Panic. Remove HackrNVMeFamily kext and then check. Also, it could be possible that your Laptop has less than 32MB DVMT which can cause KP. Ensure that your kexts are up to date.
