intel uhd 620 9th canot be detect and full accelerated
majdjalabi
Intel Cannon Point-LP
Core i7-8665U 4 x 1.9 - 4.8 GHz (Intel Core i7)
Intel UHD Graphics 620, Core: 1150 MHz, 25.20.100.6577
10.12.x
  1. Other
i have dell latitude 4700 2 in 1
i install sanoma and everything working using oprncore 8.8 except graphic card get 7 mb only
please help
please help
Sir
I reviewed and nothing missing found
May you help me to clarify what wrong or missing in my EFI
Sir
You did not follow the guide. If you have followed, the config.plist should have a change.
Here are a few issues
- The SSDT loading order is not correct. Important SSDTs should load first.
- Remove SSDT-OLARILA-MOBILE.aml. The guide does not involve using any foreign SSDT
- Remove the patch from ACPI>Patch section.
- Remove FadtEnableReset from ACPI>Quirks section
- Remove ResetLogoStatus Quirk from ACPI>Quirks section.
- Remove the entries from ACPI>Delete section.
- Remove the entries from Booter>MmioWhitelist section.
- Disable EnableWriteUnprotector and enable RebuildAppleMemoryMap.
- Set the device-id as A53E0000 instead of AD3E0000 which is invalid in the DeviceProperties>Devices section.
- You have literally added kexts for numerous ethernet and WiFi. Use only specific ones as per your system.
- Remove LapicKernelPanic from Kernel>Quirks. It's mostly required on HP systems.
- Disable HiberanateSkipsPicker from Misc>Boot section.
- Set the SecureBootModel to Default in Misic>Security section.
- Remove watchdog=0, -igfxblr, -noDC9, igfxagdc=0, -wegnoegpu, uia_exclude=USR1;USR2 and lilucpu=9 from boot-args from NVRAM>7C436110-AB2A-4BBB-A880-FE41995C9F82 section.
- Disable SIP using 67000000 as csr-active-config value.
- Remove UnblockFsConnect from UEFI>Quirks section. It's mostly required on HP Systems.
sir
i use attache EFI and everything working fine ecept graphic card not full accelerated as it detected 7 mb only
kindly review the file and provide me what missing or wrong
appreciated all your efforts and supports
sir
sir
sir
Firstly, do not copy/paste things over and over again.
Secondly, you did NOT follow the instructions. Your config.plist has no such changes which was required to do.
Rajala1404
