Intel UHD 620 KBR-L iGPU acceleration issue
AstronxD
Asus ROG Maximus XII Hero
I9-11900K
Sapphire RX6900XT Nito+ SE
15.x
  1. iMac Pro
DELL Inspiron 15 3576
Motherboard: DELL 0K83NX (BIOS 1.16.0)
CPU: Intel core i5 8250U (Kaby Lake Device-id:0x5917) FB: 0x591B0000
GPU: Intel UHD 620
dGPU: AMD Radeon 5 M520 (Disabled to support new MacOS)
I have tried
AAPL,ig-platform-id: 00005916, 0000C087, 00001659, 00001B59
device-id: 16590000
framebuffer-patch-enable: 01000000
framebuffer-stolenmem: 00003001
framebuffer-fbmem: 00009000
when using 00001659 or 00001B59, I get black screen. and with other ids i get 7mb gpu acceleration.
GPU: Intel UHD 620
I have tried
device-id: 16590000
What's the screen resolution?
Any help please. Anyone
Your Laptop might need EDID patching or your screen might not be compatible. Also, are you sure its blackscreen and not the backlight issue?
How can I know for certain and how can I patch EDID. Also how to know if screen is compatible for this laptop. I can see the backlight glowing. IMG20250517163744.jpg
How can I know for certain and how can I patch EDID. Also how to know if screen is compatible for this laptop. I can see the backlight glowing.View attachment 9448
Firstly, check if the external ports are tied to IGPU or dGPU. If its connected to IGPU, connect external monitor and check if you get the display. If you get the display, you can check things further.
jorgelreza
