No acceleration and 3mb VRAM on HD 530 in Ventura 13.5.2
User5690
H110M Pro-Vd
Intel Core i3-6100
HD Graphics 530
Hello, everyone. I'm trying to make my igpu work . I tried many workarounds , can you help me? Maybe I skipped one that will work for me. I'm using Ventura 13.5.2 / Cpu: Intel Core i3 6100 / Motherboard:MSI H110M Pro-Vd connected via DVI to hdmi adapter to my TV. Here's what already tried after applying system loads only 1/3 of the loading bar and no signal appears.
Update : stuck on 1/3 of the loading bar and screen is flashing , every few seconds
Here it is, my post on tonymacx86 was deleted when i uploaded my efi . I'm new to this.
Okay, what now?
Now , I'm getting this error
Your configuration is still not correct.
100 series does not require SSDT-PMC. Moreover, if you're using IGPU only, what's the reason to use SSDT-BRG0? As its a Desktop, what is SSDT-PNLF doing here?
Read the guide again and prepare the EFI from scratch.
Added only USBX still getting error on photo
kcbednar
