How to Obtain OpenCore config.plist
An EliteMacx86 Exclusive Guide - This guide covers obtaining config.plist for OpenCore bootloader.
To obtain config.plist for OpenCore, you need to download OpenCore.
1. Download the Release folder followed by the release version.
When extracting, you'll get 4 folders which have been listed below.
| Directories | Purpose |
| Docs | Contains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore |
| IA32 | Contains OpenCore EFI, 32-bit OpenCore Boot Loader |
| Utilities | Contains several utilities |
| x64 | Contains OpenCore EFI, 64-bit OpenCore Boot Loader |
2. Copy
sample.plist from Docs to your working directory and rename it to config.plist.To edit your config.plist
GUIDE - How to edit config.plist [Clover/OpenCore]
How to edit config.plist [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers editing of Clover and OpenCore config.plist using several methods. You can use this guide to edit your config.plist even on Windows or Linux. Clover and OpenCore config.plist is in XML format which...
elitemacx86.com
For Intel Desktops
GUIDE - How to Create OpenCore Config.plist file for booting macOS on Intel Desktops
How to Create OpenCore Config.plist file for booting macOS on Intel Desktops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Desktops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the...
www.elitemacx86.com
For AMD Desktops
GUIDE - How to create OpenCore config.plist for booting macOS on AMD Desktops
How to create OpenCore config.plist for booting macOS on AMD Desktops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on AMD Desktops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the Hackintosh and...
www.elitemacx86.com
For Intel Laptops
GUIDE - How to Create OpenCore config.plist file for booting macOS on Intel Laptops
How to Create OpenCore config.plist file for booting macOS on Intel Laptops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Laptops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the Hackintosh...
www.elitemacx86.com
