"An error occurred preparing the update"
Aman Jain
Hp 450 g6
i7 8th gen
Intel graphics
11.0.x
I got this error everytime when I try to update my mac and this error occured at the last 1 min remaining ,is there is any way to fix because i don't want to format the disk because it hold some of my data , projects
Anyone ,Any help pls
What's the current version of macOS you're using now?
Make sure your NVRAM is working. Clean the old Update files and try to upgrade again.
But i am not get clear nvram option in bootloader , and what do you mean by old update file ,do you mean macos Monterey installer app
The Update folder is located at Library/Updates. Delete all contents, empty bin, restart, reset NVRAM twice, download the full installer and proceed with upgrade.
Still having the same error while updating
what is PR File ??
MONUKUMARPPT
