MacOS Mojave 10.14.5 (18F132)-GPU?
dbestal
Gigabytes H110M-D2
I5 7500 INTEL
GTX 1050TI DUAL STORM
10.14.x
MacOS Mojave 10.14.5 (18F132) how to install GPU GTX 1050ti?
Done installation using hdmi cable all are working no need to use hd630.
however i was not able to recognize the gpu nvidia gtx 1050 but i can use it using HDMI.
any work around to install the driver?
You can't use it, there is no nvidia web driver for macOS Mojave, you either need to use High Sierra or you must change the GPU or switch to iGPU.
Hi Cyberdevs,
Is it possible to release? When might it be?
Thanks
Hi Cyberdevs,
Thanks
There is no any NVIDIA WebDrivers since macOS Mojave and i don't think there will be. You've got two options. Either switch to any compatible AMD GPU or use Intel UHD Graphics. It's time to say Good Bye to NVIDIA. :)
Thanks for your reply.
Yes, it's time to say goodbyt to Nvidia... even my NV card is new :cry:
I am planning to buy the MSI RX580 ARMOR 8G OC, Is this card OK? It seems to support Catalina.
You're welcome.
I had to sold off my EVGA GTX 1080Ti which was barely used for couple of months on a regular basis.
That's fine. I've tested that card. But i always prefer Sapphire one. :)
I am sorry to hear that you have to sold off a good display card, just because of the commercial consideration between Apple and Nvidia. :(
Thank you for your valuable advice, but this brand of display card is difficult to buy in Taiwan, considering the follow-up warranty and maintenance, I must give up. :eek:
Yeah
I've used MSI. You're good to go with MSI. It performs well and works OOTB. :)
I am sorry, because I have a problem again. . .
After I switch the display card to MSI RX580 ARMOR 8G OC, the display looks normal (such as the BIOS), but the color changed after entering Mojave.
I don't know if this is a hardware problem or do I need to adjust the system?
Thanks
Thanks
Check your EFI folder and make sure you are using the latest version of Lilu and WhatevrGreen and do not inject anything GPU related except for iGPU setting if it is enabled in BIOS/UEFI.
ANARKRUTOI
