WiFi Compatibility List for OS X and macOS [Broadcom, Atheros, Intel and Realtek]
Following are the list of compatible and non-compatible WiFi models for Mac.
For Broadcom
GUIDE - How to Enable Broadcom WiFi and Bluetooth on macOS [Clover/OpenCore]
How to Enable Broadcom WiFi and Bluetooth on macOS [Clover/OpenCore] This guide describes how to enable Broadcom WiFi and Bluetooth on macOS using Clover and OpenCore. By following this guide, you'll be able to enable Broadcom WiFi and Bluetooth on your non-Apple computer running macOS using...
www.elitemacx86.com
GUIDE - Enabling WiFi Support for Atheros Based WiFi Adapters
As of the first release of macOS Mojave, Apple has removed the support for Atheros based WiFi adapters by removing the AirPortAtheros40.kext file from the IO80211Family.kext/Contents/Plugins so if you have been using one of those cards you need to add the missing AirPortAtheros40.kext back to...
www.elitemacx86.com
GUIDE - How to Enable Intel WiFi and Bluetooth on macOS [Clover/OpenCore]
How to Enable Intel WiFi and Bluetooth on macOS [Clover/OpenCore] This guide describes how to enable Intel WiFi and Bluetooth on macOS using Clover and OpenCore. By following this guide, you'll be able to enable Intel WiFi and Bluetooth on your non-Apple computer running macOS using Clover or...
www.elitemacx86.com
Broadcom
| Vendor | Model | Form Factor | Standard | Range | Chipset | VEN ID: DEV ID | OOTB | Sierra | High Sierra | Mojave | Catalina | Big Sur | Monterey | Ventura | |
| Broadcom | BCM943602 | 14E4 | Y | YES | YES | ||||||||||
| Broadcom | BCM94360NG | 5GHz | 14E4:43a0 | Y | Y | Y | Y | Y | YES | YES | |||||
| Broadcom | BCM94352 | 5GHz | 14E4:43B1 | Y | Y | Y | Y | YES | YES | ||||||
| Broadcom | BCM94350 | 14E4 | Y | YES | YES | ||||||||||
| Broadcom | BCM943224 | 14E4 | Y | ||||||||||||
| Broadcom | BCM94331 | 14E4 | Y | ||||||||||||
| Broadcom | BCM94322 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4311 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4318 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4306 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4309 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4321 | 14E4 | Y | ||||||||||||
| Broadcom | BCM4322 | 14E4 | Y |
Notes:
- Since release of macOS Sierra (10.12), Apple dropped support for old Broadcom BCM431x and BCM4321 cards respectively. There is no workaround, they must be replaced with a supported one.
- Since release of macOS Catalina (10.15), Apple dropped support for BCM4322 (14e4:432b). AirPortBrcm4331 plugin from IO80211Family kext was abandoned and no longer in use. This affects cards such as DW1510. A workaround is to simply install macOS Mojave's IO80211Family kext.
| Vendor | Model | Form Factor | Standard | Range | Chipset | VEN ID: Dev ID | OOTB | Sierra | High Sierra | Mojave | Catalina | Big Sur | Monterey | Ventura |
| Qualcomm | AR242x | 1969 | NO | NO | ||||||||||
| Qualcomm | AR542x | 1969 | NO | NO | ||||||||||
| Qualcomm | AR5416 | 1969 | NO | NO | ||||||||||
| Qualcomm | AR5418 | 1969 | NO | NO | ||||||||||
| Qualcomm | AR9280 AR5BHB92 | 1969 | YES | YES | YES | YES | NO | NO | ||||||
| Qualcomm | AR9285 AR5B95 | 1969 | YES | YES | YES | YES | NO | NO | ||||||
| Qualcomm | AR9287 AR5B97 | 1969 | NO | NO | ||||||||||
| Qualcomm | AR9380 AR5BXB112 | Mini PCIe | A/B/G/N | 168c | NO | NO | ||||||||
| Qualcomm | AR5B91 | Mini PCIe | B/G/N | 168c | NO | NO | ||||||||
| Qualcomm | AR5BXB6 | Mini PCIe | A/B/G | 168c | NO | NO | ||||||||
| Qualcomm | AR5BXB72 | Mini PCIe | A/B/G/N | 168c | NO | NO | ||||||||
| Qualcomm | AR9485 | 1969 | YES | YES | YES | YES | NO | NO | ||||||
| Qualcomm | AR9565 | 1969 | YES | YES | YES | YES | NO | NO | ||||||
| Qualcomm | AR9462 | 1969 | YES | YES | YES | YES | NO | NO |
Notes:
- Since release of macOS Mojave (10.14), Apple dropped support for Atheros cards. A workaround is to install the Atheros40.kext from High Sierra.
- Since release of macOS Catalina (10.15) it no longer supports injection of High Sierra's AirPortAtheros40.kext. A workaround is to install High Sierra's IO80211Family kext.
- There can be speed limitations.
| AC Series |
| Manufacturer | Model | Form Factor | Standard | Range | Chipset | VEN ID: DEV ID | OOTB | Sierra | High Sierra | Mojave | Catalina | Big Sur | Monterey | Ventura |
| Intel | AC 7260 | Half Mini PCIe PCIe NGFF | A/B/G/N/AC | 8086: 08B1 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 7265 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 8260 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 8265 | NGFF | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 9260 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 9461 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 9462 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 9560 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 3160 | Half Mini PCIe | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AC 3165 | NGFF, M.2 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | YES | |||
| Intel | AC 3168 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES | |||
| Intel | AC 4165 | A/B/G/N/AC | 8086 | N | Y | Y | Y | Y | Y | Y | YES |
| AX Series |
| Intel | AX200 | NGFF, M.2 | A/B/G/N/AC/AX | 8086 | N | Y | Y | Y | Y | Y | Y | YES | ||
| Intel | AX201 | NGFF, M.2 | A/B/G/N/AC/AX | 8086 | N | Y | Y | Y | Y | Y | Y | YES |
Notes:
- As of now, all Intel WiFi Cards are unsupported on OS X/macOS and the development for the cards has been provided by third party developer.
- On some systems, the BT may not work with or without conjunction of WiFi.
- Handoff and AirDrop doesn't works on most of the models.
Additional Notes:
All Ralink and Realtek Cards are unsupported at the moment under macOS. Currently, there is no support from any Third Party Developer.
| ASUS |
| ASUS | PCE-AC66 | PCIe | A/B/G/N/AC | BCM4360 | 14E4: 43A0 | Y | Y | Y | Y | Y | Y | Y | |
| PCE-AC68 | PCIe | A/B/G/N/AC | BCM4360 | 14E4: 43A0 | Y | Y | Y | Y | Y | Y | Y |
| TP-Link |
| Vendor | Model | Form Factor | Standard | Range | Chipset | VEN ID: DEV ID | OOTB | Sierra | High Sierra | Mojave | Catalina | Big Sur | Monterey | Notes |
| TP-Link | TL-WDN4800 | PCIe | A/B/G/N | AR9285 | 168C: 002B | Y | Y | Y | Y | Y | Y | Y | Requires patching since Mojave | |
| Archer T9E | PCIe | A/B/G/N/AC | AR9380 | 168C: 0030 | Y | Y | Y | Y | Y | Y | Y | Requires patching since Mojave |
