instalation monterey on acer aspiere e1 572g
stick with mojave as you know that works?
on mojave my touchpad works only partialy i can only move cursor but not click
im trying to do this your way but View attachment 5852
also, what makes you think your trackpad will work any better?
make sure your kexts are listed in order in your config.plist properly ie:
<dict>
                <key>Arch</key>
                <string>Any</string>
                <key>BundlePath</key>
                <string>VoodooPS2Controller.kext</string>
                <key>Comment</key>
                <string>Touchpad</string>
                <key>Enabled</key>
                <true/>
                <key>ExecutablePath</key>
                <string>Contents/MacOS/VoodooPS2Controller</string>
                <key>MaxKernel</key>
                <string></string>
                <key>MinKernel</key>
                <string></string>
                <key>PlistPath</key>
                <string>Contents/Info.plist</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>VoodooPS2Controller.kext/Contents/Plugins/VoodooPS2Keyboard.kext</string>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VoodooPS2Keyboard</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>VoodooPS2Controller.kext/Contents/Plugins/VoodooPS2Mouse.kext</string>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VoodooPS2Mouse</string>
                <string></string>
                <string></string>
            </dict>
<dict>
                <key>Arch</key>
                <string>VoodooPS2Controller.kext/Contents/Plugins/VoodooPS2Trackpad.kext</string>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VoodooPS2Trackpad</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>VoodooPS2Controller.kext/Contents/Plugins/VoodooInput.kext</string>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VoodooInput</string>
                <string></string>
                <string></string>
            </dict>
in monterey instaler works like it should i can clik not only move
run with admin privilege
it is runned with admin privilege
ok now i need go to sleep i will keep trying tomorow
maybe im wrong but as far as i see this need to be only on OC not in clove
im give up with this sorry for bothering you guys
from your image above, you are using opencore as a boot loader which is why i said about kext order
I have one more problem with mojave the laptop does not turn off completely it looks like it is complety off but the hard drive led is still on
Have you've found a solution for this?
Zementos
