instalation monterey on acer aspiere e1 572g
tabs12
acer espire e1 572g
Intel® Core™ i5-4200U
AMD Radeon HD 8750M 2GB / HD Intel® 4400
Sorry for my english
Hi i want install monterey on my laptop acer aspiere e1 572g using clover i found maching EFI for it but there is no kext for my ethernet card bcm57786 14e4 16b3 i found working kext for my intel wifi card its not original wifi from this laptop and thi wifi is a way to slow first it shows 2h and 16min to finish instalation then jump to 28h i dont want wait that long and then use this slow wifi card in os itself can someone help me find kext for my ethernt it will be much faster my ethernet was workin on mojave but kext form mojave for my ethernet not work in eny newer mac os or insted of this i can use mojave but for mojave i will need kext for my touchpad becouse on mojave i can use it only for moving cursor nothig more but on monterey instaler touchpad work like it should but kext for it from monterey not work in mojave
For BCM57786, you'll need to use FakePCIID+FakePCIID_BCM57XX_as_BCM57765.kext
i was trying but it wasynt work in enything newer then mojave or maybe i did something wrong i jut copied this FakePCIID+FakePCIID.kext and BCM57XX_as_BCM57765.kext to efi/clover/kexts on my instalation usb but it shows that i not have internet conection its same thing that i use on mojave and on mojva works but not work on any newer os
Which version are you trying to install?
if you mean version of mac os i want install monterey
unfortunately no only windows 10 PC and laptop acer aspire e1 572g without os for now
Oops. Best is to use VMware or VirtualBox and create offline installer.
my pc i probably to weak to run VM with mac os but i can try do that if you tell my how . after instaling mac os on my laptop from ofline installer my ethernet will work?
It may work. Install it and then we can check further!
mulineee21
