MacPro5,1 Thunderbolt
my titan ridge stays at 20gb and not like a thunderbolt 3 at 40gb and the hotplug doesn't work
See here:
oui j'ai vu mais comme c'est en anglais et mon traducteur reste approximatif. Je ne vais pas faire cela et faire une erreur qui ruinera ma machine. y a-t-il un fichier à remplacer par un autre qye que je peux télécharger ? merci pour votre aide patrick
yes I saw but as it is in English and my translator remains approximate. I'm not going to do this and make a mistake that will ruin my machine. is there a file to be replaced by another qye i can download? Thank you for your help patrick
Really not sure what you want to say. Can you please re-phrase it?
yes I saw. but the debate is in English and my translator remains approximate. So I'm not going to start following this method and make a mistake that will ruin my machine. Is there a file to replace with another that I can download? Thank you for your help patrick
There is no baked recipe here. You must learn with the help of guides.
Warfun193
