- Jun 5, 2021
- Asus WS X299 Pro
- Intel Core i9-10980XE
- AMD Radeon RX 590
- 14.x
- iMac
Hi all! Recently I wanted to update my very good and stable working Hackintosh to Sonoma 14.4, but I started getting strange issues. Firstly after some time WiFi stopped working at random. I followed the guide to restore it and went well and worked to last week when after booting up it stopped to discover and connect to networks. The card itself and Bluetooth works fine. Then when I wanted to check for update's (after 14.2.1 update) none of the system patches were showing up. Today I wanted to do it manually and downloaded fresh copy of Sonoma from AppStore and flashed it on USB and tried to update it from recovery environement . But before that I tried to launch it from OS itself but it was giving me an "a snapshot is currently set to boot that is not the currently booted snapshot. Please reboot" but after couple of trials I gave up. So I've launched the update from USB but right now it's stuck at Stage 2. It boots correctly, OC 0.9.7 config works fine cause WhateverGreen (which is my last kext) loads and it works od 14.2.1 so... It even passes that stage when it shows "X minutes remaining". After that it does reboot and gets into boot loop. 14.2.1 installs perfectly fine. Does anybody knows what might be an issue here? Any help appreciated. Cheers!
EDIT: 14.3.1 also works perfectly fine
