SOLVED Sleep not working
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
Hey team EliteMacx86,
I wanted to get my sleep working for my laptop (HP Elitebook 840 G3) but it only works if I remove anything which is plugged in (Charger,Pendrive,dongle,etc) and the close the lid for it to go to sleep other wise it will stay on power.I have mapped my USB according to the guide. Please help me fix it I will attach my EFI .
Please and thank you.
Incomplete PR files attached.
Here are the PR FILES.
ACPI is not patched.
Ohh yep I fixed it. Thank You :)
One doubt, Should I keep my old Prebuilt ssdt.aml files or should I remove them???
See the configuration in the DSDT patching guide.
Okay Thank You :)
I had a problem wth brightness not changing but I managed to fix it using the AppleBacklightFixup.Kext in and using the SSDT-PNLF.aml.(By RehabMan)
ThankYou for everything 😆❤️
That's depreciated now and is no longer required. All you need is WEG+SSDT=PNLF (The IGPU rename must match in the DSDT and the SSDT-PNLF). For Brightness Hotkeys you can patch the keys.
You're welcome. Closing this thread.
gusknzn
