Need help
42n00b
Gigabyte B660
Intel Core i5-13400F
AMD Radeon RX 6600 XT
Hello, I have the laptop with this specs
  1. Ryzen 7 5800H Cezanne
  2. Cezanne [Radeon Vega Series / Radeon Vega Mobile Series]
  3. Navi 23 [Radeon RX 6600/6600 XT/6600M]
  4. MT7921K (RZ608) Wi-Fi 6E 80MHz
  5. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  6. Renoir/Cezanne IOMMU
  7. product link
I was able to install Ventura in the system, but I could not install Sonoma. I want to install sonoma and turn on virtualization, pl help
Extra> After the installation, my graphics card showed 7MB. What should I do to use the non-integrated card?
Also, I cannot disable the APU GPU in the BIOS, bios is also updated, please help.
What's the Laptop Model?
You'll have to attach PR Files
Reactions: 42n00b
Hello
its MSI Alpha 15 BEEK.
The EFI partition was disappearing every time I reset it. I couldn't find a solution and my EFI files were deleted by mistake.
I will follow the dortania again for re-installation and will send you the necessary information ASAP. Thank you for your interest.
Sounds good!
sir getting mach reboot followed ur guide too I have this same laptop
here is the efi followed ur guide to make this. getting this error memory stack shot succeded mach reboot. can u help please 🙏🏻
Enable SetupVirtualMap and change the CPUR.
raymondleung416
