Need help getting igpu acceleration on hd4600
Sealsealy
Gigabyte ga-h81m-ds2
i5-4400
Hd4600
12.x
Hi, I seem to be stuck at this every time I try device-id 12040000 which is the device id for hd4600 it won't work and will be stuck, but when I use what someone told me device-id 00131292 it seems to work until I get into MacOS and then realize no igpu acceleration
My specs:
Cpu:intel core i5-4400
Gpu: igpu hd4600 output vga
Ram: 4gb
Motherboard: Gigabyte ga-h81m-ds2
I will attach my config.plist below
My specs:
Ram: 4gb
EFI is from MaLd0n, speak to him about it? what did he say?
My specs:
Ram: 4gb
EFI is not as per the guide and the VGA isn't supported. You'll have to use an adapter.
kcbednar
