SOLVED My Efi is nod ok?
Here its io ports
Here its io ports
Adjust the following settings:
Internal Graphics: Disabled (If you don't have the need of IGPU on some other OS, better to disable it)
Above 4GB MMIO BIOS assignment: Enabled
GNA: Enabled
Also, ensure that your BIOS is up to date and the OC and related kexts as well. Do a few NVRAM resets and then try to boot via the installer.
Okay I try it
It was only due to the settings
GNA: Enabled
Thx bro
GNA: Enabled
Thx bro
Hopefully, you should see the installer now!
Yess its all ok
Reactions: magarcina
chrisgamessss
