GUIDE How to Fix GPU Coil Whine on macOS
If you're using macOS, you may have come across a weird noise from your Graphics Card when at normal load. The noise is much more clear when the GPU is under load, performing heavy load tasks.
Sometimes, even low tasks such as browsing website or reading PDFs, the coil whine issue can be noticeable.
What is Coil Whine?
Using Device Properties
Using SSDT
lovos33
