need to find the good SSD NVME case
i just plug in the pci card and add aml so just trying to figure out what's working or not
I asked how are you testing the TB Device against HotPlug.
yes but i know what you gonna tell me
i just see that plug my HDMI to MINI DISPLAYPORT cable is not working
trying to fix SM bus while figure out wich SSD NVME case i should get
That's wrong. If you're trying to use a Thunderbolt Display, here is how you can set that up.
A passthrough cable should be connected from your GPU Display Port to Thunderbolt mDP. Then either use Type-C port on the Thunderbolt Card for Thunderbolt Display or use the Display Port on the Thunderbolt Card.
hubalala
