Hi There!
I'm here because you might be able to help me with my quite unique issue as far as I see.
Only this guy name neonz had a similar issue on this forum, only difference he has another revision of the same mainboard as I have (Gigabyte Aorus Master X570). His has the Thunderbolt Header, mine has not (But the Thunderbolt Options in the BIOS are available anyway because it was originally intended to have it but Rev 1.0 did not have it then.. kinda complicated)
So, my Issue at the moment is the SSDT.
As soon as I put the SSDT into the regarding Directory on my EFI and activate it in the PLIST my MacOS does not boot anymore. It is able to get to the white apple with the loading bar, makes it to about 5% and stops moving. I have to manually Power Off the PC.
After restarting with the SSDT removed from the plist I'll get an Apple Error Report which does not really say anything usable and that's it.
I've attached my latest version of the SSDT, but no matter what I'm changing, the result seems to be the same: stuck on the loading bar.
OpenCore's Debug on the EFI says:
22:911 00:005 AAPL: #[EB|LOGT] 2023-01-10T16:00:37
22:922 00:011 AAPL: #[EB|LOG:EXITBS:START] 2023-01-10T16:00:37
so this seems to be fine.
The difficulty on this SSDT for me is, that this mainboard has quite a long path for the Thunderbolt device: PCI0.BXBR.BYUP.BYD2.BYS2 instead of this PXSX-style pathes.
And I guess it's something wrong with the SSDT because as soon as I activate it in the PLIST (and of course adding it in the EFI/OC/ACPI-Directory) it won't boot.
Today I finally got my flashed Titan Ridge. But there's no difference in the "no-boot"-issue. But I see the device in the System Report at least:
This was empty before. Anyways, the device does not work. I get no connection to the device. I guess because Hotplug does not work yet without the SSDT.
I hope you can help me. Thanks in advance and I try to give all the missing information as fast as possible.
BR
Jay
Details:
1. Thunderbolt Chip and Family: Titan Ridge 2.0 (JHL7540) FLASHED and also one with Original Firmware.
2. Thunderbolt Vendor/Manufacturer: Gigabyte
3. Thunderbolt Type (Onboard or AIC): AIC
4. Thunderbolt AIC PCI Slot Location: SLOT 4 (last slot)
5. THB_C header Availability: NO and Bridged Pins
6. TB BIOS Settings Availability: YES (set to no security and memory allocated is default settings of 128mb)
7. Motherboard Model: Gigabyte Aorus X570 Master Rev 1.0
8. CPU Model: AMD 5800x3d
9. macOS version: latest Ventura
10. Copy of IOReg: attached
11. Kextcache output:
kextcache -i/
Unknown option '--check-rebuild'
Incomplete PR Files attached. Provide the PR files as described in the FAQ:
READ FIRST! macOS/OS X Frequent Questions
macOS/OS X Frequent Questions - FAQ Before posting your queries, several common questions have been already answered and some exist in the sticky threads in the dedicated support forum. Read this post before you start your journey with macOS/OS X and before posting your doubts and queries...
elitemacx86.com
Your implementation isn't correct. You must adapt the SSDT correctly. Moreover, your configuration is not as per the guide.
GUIDE - How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide
How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide Booting the OS X/macOS installers on a non-Apple computer can be challenging for new users. This guide is intended for those who wish to use OpenCore as a Bootloader and it covers a...
elitemacx86.com
