hi from CIS.
That could be due to GPU not working. R9 380 may require Fake ID to work. What's the Device ID though?
Regarding fixing your USB Ports, see below:
Regarding USB Mapping, see below:
Maybe its usb, even tho i mapped it. EFI is already sent
Your EFI is NOT as per the guide.
Why are you injecting DSDT?
Why are you using TSCAdjustReset and CpuTscSync together?
The USB ports aren't working likely due to missing USB renames. You'll have to use the following renames for X79 chipset:
Rename EUSB to EH01
Rename USBE to EH02
Plus, the mapping kext you have isn't proper. Only two ports are mapped. Re-map the USB ports according to the guide linked in the previous post.
Rename EUSB to EH01
Rename USBE to EH02
Plus, the mapping kext you have isn't proper. Only two ports are mapped. Re-map the USB ports according to the guide linked in the previous posti
After i send you my EFI, i rechecked your answer and did renaming usb. i have 6 ports, in USB mapper i have only 3 hosts, so i choose 2 hosts, where is my keyboard, my macOS recovery with EFI, mouse, etc. Also: I deleted TSCAdjustReset and my keyboard with mouse are getting detected again. I left only cputscsync. I get these artefacts again, so i am gonna remaking my SSDT-GPU-SPOOF and maybe trying to delete DSDT, because dortania says so
Sending artefacts
Ok, i remade my SSDT patch, but it still does not work. I turned off WhateverGreen (because someone in insanelymac/amdosx said so), still does not work. New EFI is pinned. I think thats a usb problem. will send results later
Rename EUSB to EH01
Rename USBE to EH02
Rename EUSB to EH01
Rename USBE to EH02
Hello again, i hardly modified my EFI again, now i have a big progress: I am stuck at 100%. Dont know what is the problem, so i am gonna send you my EFI later.
Hello again, i hardly modified my EFI again, now i have a big progress: I am stuck at 100%. Dont know what is the problem, so i am gonna send you my EFI later. Back on Big Sur
100% before GUI recovery
-v does not work for some reason
Why the heck you still have the DSDT enabled? You were supposed to remove that.
Why are you using DevirtualiseMmio quirk? That shouldn't be needed. Also, you're using RebuildAppleMemoryMap+EnableWriteUnprotector together? You should only use EnableWriteUnprotector and disable the RebuildAppleMemoryMap.
Next, you're using SSDT-GPU-SPOOF and also using device property to achieve the same but you should use only one method, not both together.
-xcpm flag is depreciated. You shouldn't amfi_get_out_of_my_way=1 and slide=32
I disabled them. Deleted device-id in config.plist. disabled WhateverGreen for some time. already deleted xcpm and amfi and slide - after reseting NVRAM - i am stuck at the black screen without any initialised USB, just black screen. But.. why DSDT? Because my BIOS is most likely - stupid. Because from china (obvious), so this is why i turned it on. I turned it off, and right now i am stuck at black screen. What did i did for some time? I sat cpus=8 cpus=6 because if i dont set this - i will get TSC desync
Pumpky
