hi from CIS.
Why the heck you still have the DSDT enabled? You were supposed to remove that.
Why are you using DevirtualiseMmio quirk? That shouldn't be needed. Also, you're using RebuildAppleMemoryMap+EnableWriteUnprotector together? You should only use EnableWriteUnprotector and disable the RebuildAppleMemoryMap.
Next, you're using SSDT-GPU-SPOOF and also using device property to achieve the same but you should use only one method, not both together.
-xcpm flag is depreciated. You shouldn't amfi_get_out_of_my_way=1 and slide=32
Thank you very much! I am stuck on this problem https://dortania.github.io/OpenCore...ues.html#keyboard-and-mouse-broken-in-big-sur
I think i am gonna fix this by myself, then i am gonna try to install macOS. How i bypassed black screen? By turning on DevirtualiseMMIO. Photo with installing menu is attached. Forgot to say: This is Big Sur.
I sharped my EFI more, turned off DevirtualiseMMIO, fixed USB, fixed the no gpu acceleration, now everything works like charm, until you will try to install Monterey. In monterey i get stuck at the same moment as AwSomeSiz. remember him? My motherboard is based on his motherboard, so patches could be similar. https://elitemacx86.com/threads/monterey-on-x79g-v1-3-e5-1650-v2-panic.894 Writing this message from Big Sur by the way. Gonna send my EFI soon. DSDT is here, now heres my founded reason: So USB would work
Yay! I made EFI that works in Monterey installer. USB also works, no momental reboots. How? Deleted bunch of nonsense ACPI's. Now i am trying to update thuru Big Sur (Yep, it works too). I also grabbed HPEF or whatever is this - from AwsomeSiz EFI. So people wont loose their time - maybe i will also upload my EFI. But without SMBIOS. Also: I will suggest it adapt to their config, especially ACPI and USB
Deleted more ACPI - writing from Monterey!
Been away for a while but glad that you made a good progress!
Hello again, and guess what? made Ventura recovery working. Thanks to MacPro7,1 and force avx on cryptex something something (dont remember) kext. May need to get back 6,1 or get iMacPro1,1 because mouse with keyboard does not work.
seetsaw
