hi from CIS.
That could be due to GPU not working. R9 380 may require Fake ID to work. What's the Device ID though?
Regarding fixing your USB Ports, see below:
Regarding USB Mapping, see below:
Maybe its usb, even tho i mapped it. EFI is already sent
Your EFI is NOT as per the guide.
Why are you injecting DSDT?
Why are you using TSCAdjustReset and CpuTscSync together?
The USB ports aren't working likely due to missing USB renames. You'll have to use the following renames for X79 chipset:
Rename EUSB to EH01
Rename USBE to EH02
Plus, the mapping kext you have isn't proper. Only two ports are mapped. Re-map the USB ports according to the guide linked in the previous post.
Rename EUSB to EH01
Rename USBE to EH02
Plus, the mapping kext you have isn't proper. Only two ports are mapped. Re-map the USB ports according to the guide linked in the previous posti
After i send you my EFI, i rechecked your answer and did renaming usb. i have 6 ports, in USB mapper i have only 3 hosts, so i choose 2 hosts, where is my keyboard, my macOS recovery with EFI, mouse, etc. Also: I deleted TSCAdjustReset and my keyboard with mouse are getting detected again. I left only cputscsync. I get these artefacts again, so i am gonna remaking my SSDT-GPU-SPOOF and maybe trying to delete DSDT, because dortania says so
Sending artefacts
FeijaoFradinho
