Hackintosh not booting
may i ask how you fixed the logo stuck at the apple screen i am having the same trouble with my Aorus X570 elite wifi with an amd ryzen 5800x and AMD RX 580
Try to create a new efi
Hi elitemacx, I successfully installed macOS Sonoma on my PC but the performance is really bad. I have also selected iMacPro 1,1
Also when I put Nooted red.kext it fails to boot and the pc restarts
No worries.
Disable ProtectSecureBoot and SignalAppleOS and Enable DevirtualiseMmio and hopefully it should boot
No worries.
Disable ProtectSecureBoot and SignalAppleOS and Enable DevirtualiseMmio and hopefully it should boot.
Hey, Can you help me fix the problem with the NootedRed?
CPU or GPU?
mng062
