Hackintosh not booting
phil_malt
ASUS TUF B450M Plus Gaming
AMD Ryzen 5 3600X
AMD Radeon R9 270X
15.x
Hello, When I try to boot the macOS installer, the logs pop up and then even more logs pop up and my computer restarts and fails to boot. (I watched the video that was saying how to dual boot windows 11 and macOS Sonoma without Mac)
What macOS version are you trying to install?
macOS Sonoma. And I have ASUS TUF B450M Plus gaming motherboard and AMD Ryzen 5 3600X proccesor.
Those are the files that I had. Would you like to check my EFI config file?
I can't send the file. It says that it hasn't got an allowed extension.
Nevermind. Make sure to rename this file to plist.
  • Sad
mng062
