Hackintosh not booting
Your EFI is not as per the guide. Attach the verbose video to check further.
Could you tell me what is wrong? I can't understand...
1000000500.jpg I reinstalled the com.applerecovery.boot. Now it gets stuck on this screen.
Ok. But I can't understand the settings that I must put for B450M and Ryzen 5 3600X. Anyways, I will try... But sorry for wasting your time too.
No worries.
Disable ProtectSecureBoot and SignalAppleOS and Enable DevirtualiseMmio and hopefully it should boot.
Reactions: phil_malt
Right. I will try.
Bruh it still doesn't boot. Actually thank you for your assistance. (I have also resseted nvram)
Anyways I fixed it. But I found another e
EFI file from the internet.
may i ask how did you fix it please i am haviing the same trouble
xmax114
