SOLVED Graphics Spoof not working (AMD Radeon R9 270X)
Try this, it should work.
Yes, but you need to allow access to the files.
Oh ok. One moment.
Seems like the SSDT is not loaded. Spoofing can be difficult on AMD systems. Try it using the DeviceProperties method. It would be more easy.
Reactions: phil_malt
Is there any guide?
Or not?
Follow the guide. You'll not need the SSDT-BRG0.
borderliner
