Blurred text
huijkkkk97
ASRock H97 Killer
Intel Core i7 4790
AMD Radeon RX Vega 56
10.13.x
My macOS Big Sur build seems to work fine, but there's this weird issue of text being blurred sometimes. It's not dependent on any application as far as I tested. I haven't found any possible solution, but I think it might have something to do with the length of the string and size of the "window". I'll make a few examples.
Right-click context menu on a folder with 38 lowercase Qs (qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq) looks normal:
But it becomes slightly blurred on a folder with 37 lowercase Qs (qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq):
On a folder with 44 lowercase As: (aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa):
On a folder with 43 lowercase As (aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa):
On Orion Browser at this window size the 2 "Start Page" tabs look normal:
On Orion Browser at this window size 3 "Start Page" tabs some of them start looking weird and blurred:
But at this window size they all start looking normal again:
What's your monitor model, resolution, and refresh rate?
Also, what cable are you using for Display?
BenQ EX2510S, 1080p resolution and 165hz refresh rate. I'm using an HDMI cable.
What is that?
HiDPI (High Dots Per Inch) displays, also known by Apple's "Retina Display" marketing name, are screens with a high resolution in a relatively small format. They are mostly found in high-end laptops and monitors.
No, as I said it's a normal 1080p display.
Are you using any sort of converter/adapter for the display? Such as DP to HDMI/VGA to HDMI
And are you overriding the EDID? Also, are you using the default color profile for your monitor?
No. I don't know what EDID is. Yes.
OhCamargo
