NVIDIA HDMI Audio Not working
It just showed something interesting in my bluetooth
My TV certainly is not bluetooth
Ok, this probably won't make a lot of sense to you because there is going to be a lot of mombo jombo between the grains of actual information which might not be even relevant.
BTW, I just realised how language forms thinking. I choose to express what sounds good in English rather than what I actually feel.
Ok, so I copied the EFI from the OC package to my efi drive and renamed the old one into EFI Clover.
I noticed that there is kexts folder in the Opencore directory structure so I put them there.
On the first boot it complained about no config so I booted into windows and copied config.pls.
I did it by running cmd [enter] diskpart [e] sel disk 0 [] sel part 1 | assign, and then opening two notepads with adm permissions to move the files and folders around in their open dialogues.
I know that the last sentence was difficult to understand, so I will repeat it. I open two sessions of a program called Notepad as an Administrator to get access to the mounted EFI (for which you obviously need Paragon)
Now, lets switch to Wisdom. I just realised I am afraid to be wise because it is scary. I do not know why. Why is wisdom scary?
So I copied a config.plist ftom clover to oc which means open core not over clocking and got this screen shot
At which point I am stuck.
I tried to find information about oc but it is scarce.
All possible guides concentrate on obtaining OSX install image which I am obviously not interested in. (I could be interested because I just noticed my card is Metal compatible)
Anyways, I would like to know how to install this Opencore please. Do you have a guide for Clover user please?
The config.plist which you use in Clover is completely different in OC. You should carefully read the installation guide as instructed in Post #15
ilikeeatingpeeandpoo
