Fix Intel HD Graphics 3000 on macOS Mojave 10.14.x and macOS Catalina 10.15.x
An EliteMacx86 Exclusive Guide - This guide covers fixing of Intel HD Graphics 3000 on macOS Mojave and macOS Catalina.
Recently, Apple announced their next release i.e macOS Mojave 10.14 for which we have been waiting for. macOS Mojave includes many new features. The most attractive feature is the Dark Theme and the GUI. With each release of macOS, Apple remove supports for old hardware. With the the release of Mojave, Apple has removed support for Intel HD Graphics 3000 Officially for all the Mac line up products from late 2010 and 2011. From Mojave, Apple does not supports any non-metal Graphics Card which requires at least Intel HD Graphics 4000, which is a metal capable Graphics.
A year later, macOS Catalina was released and fact that since Mojave, the Graphics isn't supported, unfortunately, the same scenario is with Catalina.
If you tend to install, you cannot even boot as the system is incompatible. However, even you trick by using boot-args and skip compatibility check, at the time of installation, you won't be able to select the drive on which you want to install. It will throw an error saying "This version of macOS 10.14 cannot not be installed on this computer". The system compatibility check can be bypassed by using a boot-arg and changing the SMBIOS in config.plist.
Users with Intel HD Graphics 3000 don't need to worry as they can install it and can also get the Graphics working with Full QE/CI. However, with the light theme, a weird darkish grey Menu Bar and Finder sidebar appears. With the Dark Theme, this issue is not present.
Before you start with this guide, please know something about the performance. Graphics enhance the performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case if you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic related issues and poor refresh rate. Also the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
BIOS Setting
The BIOS settings has been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
www.elitemacx86.com
Config.plist
The config.plist file must be as per the guide.
For Clover:
www.elitemacx86.com
For OpenCore:
www.elitemacx86.com
DSDT Patching
For a Laptop, the DSDT patching is necessary in order to achieve the full functionality of the hardware. For more information on DSDT and SSDT patching, refer to the guide linked below.
www.elitemacx86.com
Notes:
Installing Graphics Kexts
The next step is to download the required kexts to enable graphics. Chris111 has made this very easy. The kexts and bundles are needed together to work with conjunction in order to enable the graphics. The installers are attached to the bottom of this post.
Run the installer and continue with the installation.
Notes:
Now you should be able to get your Intel UHD Graphics 1536 MB will full QE/CI. And your Dock would be also transparent.
Problem Reporting
Details:
Credits:
Artur for testing
Sebastiaan for testing
Chris111 for the package
Sample Attachment
The Intel HD 3000 from Dell Latitude E6320, and ASUS N53SV are used as the example in this guide.
| Graphics | Intel HD Graphics 3000 |
| macOS Version | macOS Mojave 10.14.x, macOS Catalina 10.15.x |
BIOS Setting
BIOS/UEFI Settings for macOS (Intel/AMD)
BIOS/UEFI Settings for macOS (Intel/AMD) Most motherboards will work with only a few changes from Optimized Defaults. However, for some systems, you must change the settings for booting macOS and optimal performance. Before you start making changes to your BIOS, ensure you're running the latest...
www.elitemacx86.com
Config.plist
For Clover:
GUIDE - How to Boot macOS Installer on Laptops using Clover (UEFI/Legacy)
Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it. Clover is one of the...
www.elitemacx86.com
For OpenCore:
GUIDE - How to Create OpenCore config.plist file for booting macOS on Intel Laptops
How to Create OpenCore config.plist file for booting macOS on Intel Laptops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Laptops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the Hackintosh...
www.elitemacx86.com
DSDT Patching
GUIDE - How to Patch Laptop DSDT and SSDTs
How to Patch Laptop DSDT and SSDTs This guide covers patching Laptop DSDT and SSDTs for macOS/OS X. By following this guide, you'll be able to patch your OEM DSDT/SSDTs. I. Overview To enable macOS features and various hardware and maintain stability, DSDT and SSDTs patching are required...
www.elitemacx86.com
Notes:
- If your Laptop has 1366x768 resolution, use HD 3000 Low Resolution patch.
- If your Laptop has 1600x900+ resolution, use HD 3000 High Resolution patch.
Notes:
- If you're using macOS Catalina 10.15.7 (19H15), do not install the Legacy Video Patch. Instead, update the system first, complete the updates and then install Legacy Video Patch.
Problem Reporting
Details:
- macOS version
- Copy of IOReg
- Kextcache output
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- For Clover, compress EFI/Clover, exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits:
Artur for testing
Sample Attachment
